Talked to the Tecumseh dealer..
Barnz
05-16-2003 11:00:57
Anyway, I talked to him today. And, he said that he couldnt get a rebuild kit for me. Is there anywhere else other then deere that I could get a rebuild kit? My engine model # is 5BV231-VH70 and the ser is 752172 Can anyone help?
Thanks,
Barnz
Karl Brandt
05-16-2003 11:58:19
 Re: Talked to the Tecumseh dealer.. in reply to Barnz, 05-16-2003 11:00:57
Barnz,
Most engines you buy the gasket set,rings,oil seals separate.
Never bought all as a kit.
Looks like you have the numbers wrong,5BV231-VH70
should be VH70 SBV231 ser 752172,this is a short block number[SBV231].
You need the rest of the number[VH70-135000 example] name Part #
rings 32595 std.
head gasket 32631
oil pan gasket 30684
valve cover gasket 27896
exhaust gasket 27930
top oil seal 32630
bottom oil seal 27897
These parts you should beable to get from a Tecumseh dealer.
Karl
Barnz
05-17-2003 00:05:24
 Re: Re: Talked to the Tecumseh dealer.. in reply to Karl Brandt, 05-16-2003 11:58:19
Ahh, thanks alot Karl.
Barnz
