'66 JD 110 tranny seal leak
andy b.
05-11-2003 20:18:01
the input shaft seal is leaking on my 110 and i'm wondering how much of a hassle it is to replace. i have the service manual, and it doesn't exactly tell you how to replace it, but seems to imply the shaft must be pressed out from the inside of the tranny (after you split the case) to replace the seal. is it possible to just remove the driven sheave and hub and replace the seal without taking the tranny apart? it looks like you could do it. yes, i know this isn't the "correct" way, but i'm not sure i want to split the tranny, since i have never done it.
thanks for any info.
andy b.
