JD 110 head bolt torque
andy b.
04-15-2003 19:55:36
i have a 1966 JD 110 that needs a head gasket replaced. what is the proper torque and bolt tightening sequence for the head bolts when i put it back together? it is a manual lift, if that matters.
thanks.
andy b.
TODD
04-15-2003 22:22:03
 Re: JD 110 head bolt torque in reply to andy b., 04-15-2003 19:55:36
ANDY
15-20 ft.lbs Looking at your head one end has 2 bolt holes and the other end has three.
#1 is top center
#2 is bottom center
#3 is center hole on end with three bolt holes
#4 is top hole on the end with 2 holes
#5 is bottom hole on the end with 3 holes
#6 is hole below #4
#7 is the only one left
andy b.
04-16-2003 05:33:51
 Re: Re: JD 110 head bolt torque in reply to TODD, 04-15-2003 22:22:03
THANKS!
i'm glad i didn't guess at the torque, as i would've thought it was 40 or so.
andy b.
