What size deck do I have on my cub 125
Andy
03-24-2003 16:29:53
I am going through a 125. The blades are really worn down. I can't find a serial# or deck size. when I measure it from outside to outside it is 48" Is this a 42",44" or 46" deck? thanks.
Wally G.
03-24-2003 17:00:58
 Re: What size deck do I have on my cub 125 in reply to Andy, 03-24-2003 16:29:53
OK, let's start with I doubt it's a 44" because it's just too much trouble to put one on a 125. I believe you have a 42" with a 22 1/4" center blade and 2 11" outer blades. Get some 3/4 flat washers of different thickness and don't forget the fiber washers. Start with the blade that is closest to the deck and use washers to shim other blades so all cutting edges are the same height. This way you won't have and uneven cut. And just so you know, a 48" deck runs about 51" wide without a discharge extention. Cub # 759-3850 for 22 1/4 blade 3759-3848 for 11" blade.
