Rims tires
Ben
12-01-2002 17:20:28
All -
Have a pair of 12" garden tractor rims that had 9.5 tires on them (23X9.5X12). Wanting to put some 8.5 lug tires (23X8.5X12)on these rims. Can you put 8.5 inch tires on rims/wheels that originally had 9.5 rubber on them? Never done this so not sure how much "give" is in the sizes. Will ONLY 9.5 inch rubber fit on these rims or will I be able to put the 8.5 lugs on them?
Thanks!!
Max
12-01-2002 17:36:34
 Re: Rims tires in reply to Ben, 12-01-2002 17:20:28
Shouldn't be a problem for in my research the 8.50 uses the same rim width as the 9.50. Now if you wanted to go to the 10.50, then you may want another rim.
