Mower pin attachment NEEDED BAD
Aric Schneider
11-14-2002 22:40:31
Let me see if I can explain what I am looking for, or a way to make this. On the bottom of Wheel Horse tractors on the front, there is a device that is welded to the frame, so that when you put the snowblower or some other front mounted implement on the tractor it attaches itself. The device is so that when you put a pin in it, then it cantilevers or something like that and locks the pin in itself. Then you push it up and it unlocks the pin. You can lock it as well so that it doesn't come unlocked from jarring. Hopefully you can understand what I mean. I need 2 of these BAD. One for each side of my frame.
Aric
Dennis
11-18-2002 13:30:27
 Re: Mower pin attachment NEEDED BAD in reply to Aric Schneider, 11-14-2002 22:40:31
I am not familiar with Wheel Horse however is there a machine shop nearby that could make the items that you need? I have done this a few time when parts were no longer available and found the shops very reasonable.
