Kohler blues
Arnold Plowman
11-12-2002 09:46:39
My series 1 Kohler 17 HP crapped out in my JD 317 tractor. I want to go to a different brand engine. Is there anything out there that will "drop in"? Im getting weary of the Kohlers.
Ron
11-14-2002 14:14:52
 Re: Kohler blues in reply to Arnold Plowman, 11-12-2002 09:46:39
I lost a rod on one of my QT-17 Bolens mowers.w/ a Kohler 17...twin.. The dealer advised to run these 1/4" over the full mark on the dip-stick.. The other one has been fine .... I replaced the blown one with a Series II--that was 15+ years ago, and it is a strong engine..!! Oh-Yea, it was $1013.oo THEN, and I installed it...!! My older Bolens QT-16 has an Onan in it.I replaced it with a "Big Bore" Onan..it has 1/4" larger Bores...A real power-house..!!! I found out that ALL small bore Onans can be bored to the Large Bore size....SO..Go for it..if you can find a good used Onan...!!
chuck
11-12-2002 13:42:18
go to www.smallenginewarehouse.com they'll be able to help you out with any questions about what will fit as well as adaptor kits.
dvogtvpe
11-12-2002 13:25:29
I think Deere Offers a kit to upgrade to a 18 hp Onan . I would imagine its kinda pricy from deere though .
the series II & Magnums are much better engines than the original KT17
Jim W.
11-13-2002 02:07:47
 Re: Re: Kohler blues in reply to dvogtvpe, 11-12-2002 13:25:29
I agree with dvogtvpe, the series II engine is a great replacement engine. Check out northern Hydraulics, you can purchase a series II drop in replacement for the JD.
Jim S.
11-13-2002 06:43:38
 Re: Re: Re: Kohler blues in reply to Jim W., 11-13-2002 02:07:47
I'd go with the Kohler Magnum, 18 or 20. Nice lil unit, not a bad job to drop it in. Onan engines and parts are pricey!
Rich in Ia.
11-13-2002 17:52:17
 Re: Re: Re: Re: Kohler blues in reply to Jim S., 11-13-2002 06:43:38
Don't give up on a Kohler Jim. I'm running a 12 and a 14 h.p., both 30+ years old and still running strong. - J.D. 120 & 140. The 317 was a known "bug" with the 17 h.p. series I. Put in a another 17 Kohler w/pressure lube and you'll be happy.
Jim S.
11-15-2002 06:21:49
 Re: Re: Re: Re: Re: Kohler blues in reply to Rich in Ia., 11-13-2002 17:52:17
Uh, yeah, that's what I said. I'd prefer the 18 or 20 Mag, though.
