Onan Engine Won't Charge
Ash
10-09-2002 18:48:19
I am working on a Wheelhorse 518-H (ID# 31180E01 15259) that has a Onan 18hp twin that won't charge. I checked the voltage at the regulator and it was 40 volts AC 10 volts DC, I would guess the regulator is bad. Is there any other checks I should make? Also the engine model and spec. are worn off does anyone know what they are, for this tractor? What is the part # for the regulator? Thanks, Ash
rick
10-11-2002 10:38:18
 Re: Onan Engine Won't Charge in reply to Ash, 10-09-2002 18:48:19
Check with the guys on yahoo groupes wheelhorsegardentractors, they can help you out
zman
10-16-2002 19:01:44
 Re: Re: Onan Engine Won't Charge in reply to rick, 10-11-2002 10:38:18
Ash Iwould guess your motor to be a B48G I can getyou a regulator through Stens.It will take 3 days through ups to get to my shop
