MURRAY I8 H.P. HAS NO FORWARD OR REVERSE
B.WASSOM
09-29-2002 17:54:18
CHANGED DRIVE BELT AND ADJUSTED IT.DROVE IT THE LENGTH OF THE DRIVEWAY AND BACK AND LOST ALL FORWARD AND REVERSE.CHECKED THE BELT AND IT WAS OK.SEEMS LIKE THE PROBLEM MIGHT BE IN THE TRANSMISSION.NO GRINDING NOISE IT JUST SEEMED TO SLOWLY QUIT.BEFORE I CHANGED THE BELT IT DID THE SAME THING.
Redrtractorman
09-29-2002 22:05:41
 Re: MURRAY I8 H.P. HAS NO FORWARD OR REVERSE in reply to B.WASSOM, 09-29-2002 17:54:18
Is it a high and low range,if it is try high range and than low range see if one works and the other dosen't
don.c
10-18-2002 19:57:41
 Re: Re: MURRAY I8 H.P. HAS NO FORWARD OR REVERSE in reply to Redrtractorman, 09-29-2002 22:05:41
Check keyway on the pulley on the trany. Might be sheared.
don.c
10-18-2002 19:57:09
