John Deere 210 Belt size needed
Mike A
06-20-2002 05:05:33
I have a John Deere 210 riding mower with a 38 inch deck. I need to replace the belt from the engine PTO to the deck. Does anyone one what size belt I should use? Thanks!
Dave
06-20-2002 17:46:05
 Re: John Deere 210 Belt size needed in reply to Mike A, 06-20-2002 05:05:33
Mike - The primary or drive belt for your tractor is JD part M47766. It has the following dimensional specs:
Effective Length 80.10"
Width 0.56"
Thickness 0.45"
With an Inclusive Angle of 32 degrees
Automotive belts will not hold up to the torque. If you don't use a John Deere mower belt, at least try to find an industrial grade belt. Otherwise, you'll be tossing your money away.
Good luck - Dave
Lou
06-20-2002 08:38:39
Gates shows a mower primary belt as a 6980.
Mike A
06-20-2002 08:48:44
 Re: Re: John Deere 210 Belt size needed in reply to Lou, 06-20-2002 08:38:39
Thanks!!!
lucas
06-20-2002 05:59:48
if you want it to work good you need the to get the original equipment belt from your dealer,,lucas
Mike A
06-20-2002 06:46:58
 Re: Re: John Deere 210 Belt size needed in reply to lucas, 06-20-2002 05:59:48
There is no dealer around here. Does anyone know the size so I can mow my grass?
