Murray deck adjustment
bg
05-24-2002 13:24:46
I just bought a used Murray GT 18hp briggs...46" cut. I cannot get the deck level. It scalps on the left side and is high in the back. The left front corner of the deck has been crunched and the metal is torn away for about 8-12" around the bottom. I just priced a new deck shell, but this has solid metal except for the torn place. Is there some secret for adjusting these bad boys?
bg
05-24-2002 17:53:52
 Re: Murray deck adjustment in reply to bg, 05-24-2002 13:24:46
I adjusted it by the instruction the Murray faxed me and it didn't help. I guess I need to do some measuring and more looking....
scooterhead
05-25-2002 04:06:42
 Re: Re: Murray deck adjustment in reply to bg, 05-24-2002 17:53:52
I had the same problem with a old murry , ended up being a bent blade . It did`nt look bad till I compared it real close with the other . If they whamed the deck it could have bent one .
Mac
05-25-2002 09:09:48
 Re: Re: Re: Murray deck adjustment in reply to scooterhead , 05-25-2002 04:06:42
Do as scooterhead suggests. But if the deck is in that bad shape it is hard to get measurements as murray sez. I usually checked the L&R measurements by setting both blades cross wise and measure from the outer tips. Front of deck should be slightly lower.
bg
05-25-2002 18:25:35
 Re: Re: Re: Re: Murray deck adjustment in reply to Mac, 05-25-2002 09:09:48
This is a 3-blade 46". I set according to factory instructions and it still won't cut right. I'm going to buy a new deck shell. I think this must have a twist to it, The blades and quills are new, and the blades seem to be in the same plane.
stergil mead
02-25-2003 16:32:47
 Re: Re: Re: Re: Re: Murray deck adjustment in reply to bg, 05-25-2002 18:25:35
I also bot a used murray like yours. Did replacing the deck work for you? My deck sags like mamaw's titties in the same location you spoke of.
