Mtd Serial and model numbers
B Harmon
04-30-2002 03:54:44
I've got a mtd riding mower that I need to get parts for. Problem is I can't make out the entire serial and model number. Here is what I have: 134y45f382 and 1H12. Any help would be appreciated
anthony morris
05-05-2005 06:09:51
 Re: mtd Serial and model numbers in reply to B Harmon, 04-30-2002 03:54:44
hi. i have a lawnflite mtd 11.5 hp with a 30"cutting blade the numbers i have are> serial number 91.062.7067 and model number 137-541-??1 could sum1 please fill in my 2 question marks as im in need of cutting down the jungle i once called my garden. thank-you
bwiesner
04-30-2002 19:26:15
134, the third didget (4) tells me it is a '94 model mower. Y is a twin cylinder engine and then you loose me, there should be another no. with the 45 and F tells me it is a 38 inch deck. Is this correct? You won't need the serial no. on this unit to get parts, but you will need the rest of the model no. Later Butch
Mark
07-19-2002 08:30:56
 Re: Re: mtd Serial and model numbers in reply to bwiesner, 04-30-2002 19:26:15
My tractor is labeled "Turf Trac" and looks like an MTD Farm King. Can you tell me anything about this model number: 41C2 81? Thanks!
