KOHLER K321A SLOW CRANKING
BOB KIEF
03-07-2001 10:56:04
THIS MOTOR WAS RUNNING FINE, WOULD START RIGHT UP.
NOW I GET A SLOW CRANK ONLY. NEW BATTERY, FULL CHARGE,REPLACE WIRES TO GROUND AND SOLINOID AND MOTOR-GENERATOR, CLEANED MOTOR-GENERATOR AND CHECKED BRUSHES ALL OK.DO NOT SEE ANY VOLTAGE ON THE FIELD COIL WHEN CRANKING? IS THIS NORMAL OR IS THE REGULATOR AT FAULT.REPLACED WIRE TO THE FIELD COIL. FIELD COIL IS NOT OPEN. DOES THE KEYSWITCH ENERGISE A SET OF CONTACTS IN THE REGULATOR FOR FIELD VOLTAGE??? MOTOR TURNS BY HAND OK.EVEN WITH THE SPARK PLUG REMOVED TURNS VERY SLOW. HELP. MOTOR-GENERATOR IS A DELCO-REMY 1101980-6L. ANY HELP THANKFULL
Dave
03-07-2001 14:01:31
 Re: KOHLER K321A SLOW CRANKING in reply to BOB KIEF, 03-07-2001 10:56:04
regulator,yes
