Fordson Tractors Discussion Forum
Super Dexta Advance timing or not?
woogs
07-12-2004 06:30:05
After having starting problems I just re-timed my injection pump, replaced the injectors, cleaned out the fuel tank and air and fuel filters. She started up fine but does not have the power she had before this tune-up. When I re-set the injector pump timing I noticed that it was slightly advanced4-5 degrees. I set it to factory specs at 20 degrees BTDC. Should I set her to her former timing? Thanks for any advice,
Woogs
tractorfix
07-29-2004 19:35:39
 Re: Super Dexta Advance timing or not? in reply to woogs, 07-12-2004 06:30:05
Super dexta was set to 26*. There is another mark at 26. Set it to that.
tractorfix
08-01-2004 19:01:23
 Re: Super Dexta Advance timing or not? in reply to tractorfix, 07-29-2004 19:35:39
Don't know where that came from, I must have stayed up too late. Super is 20, sorry if I confused you.
