Fordson Tractors Discussion Forum
Fordson F Dash No Mfg. Dates ?
George
07-09-2004 07:01:33
I found a fordson dash at a sale and was wondering what year it may be ?
It has no cast markings at all and no fender mounting bracket holes, the case also has no breather opening. Can you tell me the year this dash is ?
Butch H
07-10-2004 20:51:43
 Re: Fordson F Dash No Mfg. Dates ? in reply to George , 07-09-2004 07:01:33
George, There were quite a few variations of dashes. Most without fender mounting holes had casting dates but not all. The early ones had a small hole drilled into the right ( where the fender mount holes are on the later versions). This is for a grommet which supports the choke rod for the Holley 234 manifold. This manifold was used until 1921 when they went to the Holley 280 which was quite similar but the choke rod ran thru the dash (no grommet hole on the right side). Fender mounting holes appeared around 1923.
