Fordson Tractors Discussion Forum
65 dexta
DAVE RYALL
06-26-2004 04:03:50
I recently changed the transmission oil in my dexta and the hydraulic arms will only come part way up now. Prior to this oil change, they operated normally, All suggestions greatfully received
Tom
06-27-2004 06:01:46
 Re: 65 dexta in reply to DAVE RYALL, 06-26-2004 04:03:50
Hi Dave, The transmission and the rear differential are two seperate units and do not share the same oil on my 62'Dexta. I believe all Dexta's are similiar in this regards. Therefore, if you did indeed change the transmission fluid, it should not have had any effect on the hydraulics which are located in the differential.
Good Luck, Tom
Stefan
06-26-2004 12:47:02
Where did you drained and where did you filled in the oil? Ragards Stefan www.fordson-dexta.de
