Fordson Tractors Discussion Forum
Engine runs rough
Wes B
04-28-2004 07:59:34
I felt like the answer to my problem had to be somewhere in the archives but could sort it out through the searches. My 61 Dexta does pretty good most of the time but has a few issues. One of the biggest right now is that the engine seems to alternate from running on 3 to 2 cylinders intermittently. Nothing in particular seems to trigger the change, it just comes and goes. I am just guessing that one cylinder drops out because that is what it sounds like, although it seems unlikely that the tractor does as good as it does on 2 cylinders. The fuel pump was rebuilt a few years back by the previous owner, but I don't know any details about what was done. Anyone got any ideas.
The next biggest problem is the height of the lift. I had a single ripper on it the other day which was quite long. After cutting a small trench across the yard for an underground fence, I couldn't get it up high enough to clear the ground. I backed it around and lowered and raised until I had trenches all over the yard and driveway. I could only get it all the way up by removing the top link, swiveling the ripper out of the way and lowering the lift all the way down and then back up. After reading the archives however I suspect that I need to tighten the item 23 rod that Burrhead has referred to in the past. I thought if I had the top plate off anyway I could service other areas. What is the best way to flush out and clean the hydraulics and gears?
I have finally solved my dexta's tendency to stick in reverse at the worst possible times by trial and error welding and reading these post. Thanks to all who contributed to that one.
Burrhead
05-07-2004 19:33:08
 Re: Engine runs rough in reply to Wes B, 04-28-2004 07:59:34
Wes most times if the engine miss started suddenly with no other indications I usually find it is dirty injector tips or maybe water in the fuel.
To clean the diff and hyd system I drain the oil and replace it with #2 diesel fuel and idle the tractor til the engine comes up to operating temp as I operate the lift.
I would bet the prob is the rod you have mentioned.
Then drain the fuel and service the lift. Be sure to put the control in lowered position and push the lift arms down to get all cleared out.
With the cover off it would be a good time to clean and service the back pressure valve. It is in the end of the steel line in the return hydralic filter.
The unloading valve could be cleaned now too.
It's the one that is in the side of the pump's external cover.
RossM, UK
04-28-2004 23:57:01
Sorry I can't help with the engine running problem or lift but am interested in your gear sticking solution. My '64 Super Dexta constantly sticks in gear as the lever jumps out of the selector.
Wes B
04-29-2004 06:51:16
 Re: Re: Engine runs rough in reply to RossM, UK, 04-28-2004 23:57:01
Ross,
The gear sticking issue is a common problem with dexta's. The end of the shifter becomes worn and comes out of the pocket or hangs up. The solution is easy enough, but may take some trial and error. You will need to remove the shifter and add some metal to the end of the shaft so it wont come out of place as it moves the gears around. I used a welder set on low to avoid removing more metal than I was adding. There are several posts here that discuss the dimensions. Check out Wayne's Dexta page at>Link
