Clutch Cross Shaft Bushes
Paul
06-18-2003 15:46:45
I am unable to source the bushes for the clutch cross shaft on a Super Dexta that I am overhauling.The sizes are 7/8" ID x 15/16" OD x 1 1/2" long. The only way I can see to get around this problem is to machine a sized brass bush & then drill & tap the housing to install a grease nipple so that lubrication can be supplied to the bush & shaft. I have to build up the shaft where she has worn over the years. Has anyone done this job satisfactorily a different way? Or does anyone know of a part from another source that fits this requirement. Non of the suppliers around here ( read east coast of Australia) can supply the required sized split bush. The original bush type has an impregnated coating that serves as lubrication. This should be a half hour remove & reinstall with the correct parts. I'ts taken a whole week of driving & telephoning to get nowhere so far. Any assistance would be much appreciated. Cheers
Paul
06-24-2003 05:17:54
 Re: Clutch Cross Shaft Bushes in reply to Paul , 06-18-2003 15:46:45
I've ended up reaming out the bellhousing holes for the clutch cross shaft to 1". Bushes that size were easy to get & came with a new fangled compound imbedded for lubrication. She shouldn't need that job doing fo another 40 years now. Just as a matter of interest Burrhead, as the standard bushes are easy to get around your way, any chance you can come up with a manufacturers name? Cheers in advance.
Burrhead
06-19-2003 04:13:54
That's a pretty standard size bushing and are easy to find around here. most all the machine shops have the bushings.
Kevin
06-18-2003 18:28:52
That is a common problem on these machines. I am pretty sure that Zafer would have those.
