Dexta 3 point?
Limpan
06-10-2003 14:28:11
I would like to be able to lift 1000kg (one long ton about 2200 pounds) with the 3 point lift.
The hydraulic system is filled with 19.3 liters 10-30W ordinary multigrade engine oil as specified in the owners manual (rewritten in Swedish 1963).
After testing with a 1000 liters water tank filled with different amounts of water I noticed that I only could lift about 620kg. After that some valve open and the tank would not lift of the ground level (I can hear a clicking sound). I have not found any specifications any ware of the 3 point lifting capacity. So should I live with 620kg because that�s the limit of my 1959 Dexta or should I start to fix my little blue gem. What should I start with?
kkactus jack
06-10-2003 15:50:18
 Re: Dexta 3 point? in reply to Limpan, 06-10-2003 14:28:11
According to the service manual the pump will flow 16.72 liters @ 1550 rpm. That was when the unit was in good condition. What rpm were you running? Were you running in Qualitrol or Position Control? I run 90w in mine, ('63 Super Dexta). I don't know where you are located, but in Texas we don't have too much cool weather.
Please advise;
Kkactus Jack
