1955 fordson majord turns over but will not start, slow cranking with a 770 battery
danny
05-10-2003 06:29:46
this 1955 has been changed to 12 volt but when i try to strat it it turns over slow and heats up the wire involved in the strearting circit help
charles
05-12-2003 09:53:54
 Re: 1955 fordson majord turns over but will not start, slow cranking with a 770 battery in reply to danny, 05-10-2003 06:29:46
After turning it over for a while,replace whichever cables are hot. An extra cable from the earth cable bolt/nut on the otherside of the heat shield to somewhere on the engine can also help,if not suspect the starter ,windings ,commutator,brushes.
scott
05-11-2003 07:00:31
Danny,
Check your wires for corrosion and make sure your terminals are clean. Also, make sure your cables are large enough for the current draw, 2/0 preferred. I had the same trouble, put new cables on it, and cranked right over.
Good luck.
ray
05-11-2003 06:37:35
danny,your tractor is originaly equipped 12 volt,do you have your battery hooked up properly.. should be positive ground,sounds like connections are backwards,or dave has said,a bad starter..
Dave
05-10-2003 16:05:26
Hi - sounds to me like a bad starter drawing too much juice.
