55 major ???
mike
04-09-2003 21:51:59
got a 55 major parts tractor obvious shifter isnt there but under the throttle is a lever that appears to have two positions and looks to be attached to the trans is this high low or what is it standard or optation thanks mike
AL (NJ)
04-20-2003 06:52:31
 Re: 55 major ??? in reply to mike, 04-09-2003 21:51:59
Mike,I have a '58 with loader & backhoe.
Up is the lower range & down is the higher range as marked on the top of the trans behind the shift lever.
Peter, U.K.
04-10-2003 00:26:02
Yes, that sounds like your high/low gear ratio lever.
