Cleaning Cylinders
R.J.
02-15-2003 19:42:12
Does anyone have a good technique for cleaing carbon out of the cylinders without pulling the head? Just read an article about trickling water into the fuel while running at a good idle - it supposedly does a great job. Of copurse, the guy who wrote the article did it with his '66 Corvair. Am hesitant to try it with an 80 year old tractor engine.
Burrhead
02-15-2003 20:45:45
 Re: Cleaning Cylinders in reply to R.J., 02-15-2003 19:42:12
I've used the water trickle and it works good. Just be sure the engine is up to normal temp before *washing* the cylinders.
With the engine about 1/2 wide open keep the water coming at a rate that will almost stop the engine.
Something else I have used is brake fluid trickled in.
It seems like the brake fluid does better but the water will work.
R.J.
02-16-2003 12:41:05
 Re: Re: Cleaning Cylinders in reply to Burrhead, 02-15-2003 20:45:45
Burrhead:
Do I trickle the water through the main gas tank? How much should I use and how do I know when it's "washed?"
Do I run any risk on doing it with water in such an old engine ('23 Fordson)?
Burrhead
02-17-2003 19:48:12
 Re: Re: Re: Cleaning Cylinders in reply to R.J., 02-16-2003 12:41:05
No you trickle it into the air inlet of the carb.
The age of the engine don't make any difference.
You use a small stream of water into the air intake and keep it trickled down so you don't compeletly stall the engine.
When it starts to stall out just let up on the water hose til the engine runs smooth and start over again. The engine will sputter and act like it is stalling out. It will stall out if you add too much water, too quickly.
I usually keep flushing for 3-5 minits.
When you get thru putting the water thru it put the engine under a load so it will burn the loose carbon out. You should see small flakes of carbon shoot out the exhaust when you load the engine.
Ron
02-18-2003 12:37:02
 Re: Re: Re: Re: Cleaning Cylinders in reply to Burrhead, 02-17-2003 19:48:12
Burrhead,
Am interested in doing this with my tractor as well. Are you familiar with the Holley 295 system for the Fordson? Where would you trickle the water through? The mixing chamber primer? There's no real air inlet valve on the carb that would allow the introduction of water.
Burrhead
02-18-2003 17:59:26
 Re: Re: Re: Re: Re: Cleaning Cylinders in reply to Ron, 02-18-2003 12:37:02
Ron I'm not familiar with the 295 at all.
I'm just thinking out loud so please bear with me.
There has to be somewhere that inducts air thru a carb. Maybe by taking the clean air duct from the air cleaner and put water thru there. If it's and updraft carb it will still suck the water in.
Paddy the water works extremely well on diesel engines that idle alot. Mack, Cummins, and Detroits even if they have turbo.
It might would screw up something on the newer air to air systems but for regular diesels without the air to air induction it works fine.
If you flush an old style 6.9 or 7.3 non-turbo Ford pickup wait til dark and load a tractor up on a lowboy and shower down on the pickup when ye get up in high gear. It'll start throwing sparks out the tail pipes that look like sparkler fireworks.
I have'nt tried it on the newer air to air systems because I would be afraid the water could mess up the oxygen and/or heat sensors in the air cooler.
Capp
02-17-2003 20:20:02
That's a new one on me Burrhead, just goes to show a feller can learn something new everyday. I'm remember that one. Does this work on all motors such as and old truck or car? Take care.
Capp
Paddy
02-18-2003 08:06:00
 Re: Re: Re: Re: Re: Cleaning Cylinders in reply to Capp, 02-17-2003 20:20:02
I shouldnt have thought this would work on a diesel, getting water in diesel never goes very well
