Clean that engine?
paul s
02-13-2003 02:21:17
Can any one help with cleaning formula and technique for inside and outside engine parts.Preferably not to toxic
kevin
02-15-2003 05:34:29
 Re: clean that engine? in reply to paul s, 02-13-2003 02:21:17
I tried everything on my Dexta, I finally ended up using easyoff. Excellent results
Capp
02-13-2003 19:51:41
I use Gunk and let it soak for 15 mins. Wash that off and let it dry then repeat again and use a high pressurer steam jenny if you got one, if you don't a garden hose will work to. Then after I get it clean this way I take kerosene and a brush and go over it again. Don't use water anymore after the kero, when you get done make sure you wipe it all down and spray a light coat of oil on everything. I just took mine to a machine shop and had it tanked or dipped in costic soda, this is the best job. It depends on how well you want it cleaned. The inside is a must to have cleaned really good, the outside only if you are going to paint it which I would. I hope this helps.
Capp
