Coolant Seeping ('57 FMD))
Jim Senger
02-07-2003 01:51:45
Hi Folks, I wrote for advivice earlier on, about my coolant blowing out. This was due to compression from the cylinders escaping into the coolant system. I got a new head gasket and put it on and got lots of seepage from the left hand side center of the gasket, all bolts were torqued to 90 ft/lbs. so I took it back off and had the head cleaned and milled (it was warped to 5 thou) and renewed the valves. I put it back on and its still comming out on the same side (left side, around #3 cylinder). Have I missed something, or done something wrong, Please Help, Im at a loss. Thanks Jim S (Ont. Canada)
Garry
02-07-2003 10:40:00
 Re: Coolant Seeping ('57 FMD)) in reply to Jim Senger, 02-07-2003 01:51:45
You may have a cylinder sleeve leaking.
