County Super 6 clutch release bearing
Huub
01-19-2003 13:40:05
Hello,
Can anyone help me with the (part) number of a clutch release bearing of a County Super 6 (Super Major base)?
Inner dia: 60 mm
Outer dia: 112 mm
Width: 35 mm
Number of bearing hub: EIADDN-7561C
Thanks in advance,
Huub
Ron
01-21-2003 08:00:48
 Re: County Super 6 clutch release bearing in reply to Huub, 01-19-2003 13:40:05
I suggest taking your bearing to an industrial bearing supplier. They can take your measurments and look up the bearing under automotive,industrial, and agricultural applications.
Motion industries,brown brearing, etc.
Since most service centers have disguarded the older books, I take bearings, seals, couplers, adapters, etc, directly to an industrial supplier. With the item and measurements they can give you the crossover numbers. If you go to an automotive bearing supplier their references don't cross into industrial application which is what the county super six and the fordson major and its engine falls under. An industrial engine supplier can get you a set of engine gaskets based on the stamped edn numbers on the block of the industrial engine. I was able to get a set of engine gaskets and seals within 3days for my county super six. Ford Holland was of no help. Motion industries looked through their data base and found my bearings and seals in a warehouse in Detroit,Mi. and had them drop shipped directly to me.
Hope this helps,
Ron,
New Jersey
john
01-20-2003 05:43:24
Hello, the release bearing part no is E1ADKN7580B. I also have the assembly part no's if you want them. Hope this helps.
John
Huub
01-20-2003 12:39:56
 Re: Re: County Super 6 clutch release bearing in reply to john, 01-20-2003 05:43:24
Thank you for your quick response, John.
The EIADKN7580B has an internal diameter of 52,388 mm and an external diameter of 81,61 mm(for instance SKF 411411) so I cannot use it.
My hub as a greasing possibility on the outside of the clutch housing with a hose going inside.
Regards, Huub
Steven B
01-21-2003 03:35:54
 Re: Re: Re: County Super 6 clutch release bearing in reply to Huub, 01-20-2003 12:39:56
My 1961 Super Major parts book lists the following for use with the 13inch clutch:
Hub E1ADDN 7561
Bearing E1ADDN 7580
My 1964 (Printed 1967) Super Major parts book lists for 13inch Industrial clutch:
Hub E1ADKN 7561 C Bearing E1ADKN 7580 B
Steven B
