56 Major Diesel Inj. Pump
TMARSHALL
11-15-1999 11:24:24
I have just purchased a 56 Major, and the Simms or pump is quite noisy. The man I purchased it from said that these tractors are just that way. I bought the tractor on his word, and the fact that it will start within one full revolution of the motor 90% of the time. Is this true, or do I need to investigate a rebuild on the pump. Does anyone know if this is a costly rebuild.
brian
11-16-1999 12:53:16
 Re: 56 Major Diesel Inj. Pump in reply to TMARSHALL, 11-15-1999 11:24:24
The clatter in the region of the injection pump is usually the drive coupling which is made of a fibre. These should be available from your local New Holland dealer. A little trick that may help is to undo the bolt fixing the front half of the drive from the engine and levering the drive backward onto the injection pump. This tightens the drive pad and will quieten things down for a short period. An idustrial type of drive with rubber inserts used to be available too.
