FORDSON F COIL BOX TEST
11-08-2002 14:06:15
How can you know for sure that a coil box is OK and able to transfer juice. Will
Theman
11-11-2002 06:12:21
 Re: FORDSON F COIL BOX TEST in reply to [email protected], 11-08-2002 14:06:15
First off, NONE of the brass contacts should be grounded to the metal box. The bottom 4 contacts are power to the 4 coils and are tied together. The wire from the magneto contact lug at the clutch housing goes to them.
The top row of terminals on the back of the box are for timing. These should be wired to the "commutator" cap on the front of the camshaft. When the roller on the end of the shaft contacts the terminal, the corresponding coil primary is grounded which opens the points for that cylinder to fire.
The bottom row of terminals on the back of the box are for the spark plug wires.
Raymond
11-24-2002 20:26:00
 Re: Re: FORDSON F COIL BOX TEST in reply to Theman, 11-11-2002 06:12:21
Also I had problems with the brass contact lugs on my coil box (after years they lose their strength and dont touch coils properly. new ones are available from model t parts sellers for around $7
