64 super major compresion help
jim k
05-26-2002 16:36:55
anyone know what the compresion should be on a 64 super major also what maximum piston hight should be i rebuilt mine and it smokes bad raw fuel and wount run smoth at any rpm im a mechanic so its a pro job with all new parts
Steven B
05-26-2002 17:14:08
 Re: 64 super major compresion help in reply to jim k, 05-26-2002 16:36:55
Ratio is 16:1, pressure is not given in the factory manual.
If it smokes bad and runs rough it is probably one injector, maybe 2 that isnt working properly. I would have the injectors tested first, piston hight will only alter the comp by a small amount and it wont make it smoke.
Steven B
Bob
05-28-2002 19:01:37
 Re: Re: 64 super major compresion help in reply to Steven B, 05-26-2002 17:14:08
My book says the compression should be 365 psi sounds like injection timing or injectors need work I rebuilt my injectors runs like a new machine
jim k
05-28-2002 19:27:48
 Re: Re: Re: 64 super major compresion help in reply to Bob, 05-28-2002 19:01:37
Thanks Bob but the injectors and pump are rebuiltalong with the rest of the engine about 5,000 dollars worth i also suspected them but installed them in another tractor witch ran ok before and it ran like twice the tractor with my parts alot of work but at least i know my fuel system checks out ok. any more help please thanks again
Bob
05-29-2002 16:11:45
 Re: Re: Re: Re: 64 super major compresion help in reply to jim k, 05-28-2002 19:27:48
Have you tried running it without the air filter hooked up?(might be plugged) the ajustment on your pump might be off might be on full throttle when the air intake flap is at Idle or it's stuck at full throttle at the pump hope this helps some
jim k
05-30-2002 17:13:46
 Re: Re: Re: Re: Re: 64 super major compresion help in reply to Bob, 05-29-2002 16:11:45
NO flap on this one Bob. Its got the late simms pump on it. I think i have the wrong head gasket (too thick) its .049 thou compressed the one i think I need is .039 thou out of the box. the compresion is low 190 to 200 on the first hit, and 360psi cranking the engine until the gauge wount rise anymore. I think thats low for a new motor anyone an old ford tractor mechanic thanks again BOb KEEP TRYING
jim k
05-30-2002 17:13:30
