Dexta liners are they dry or wet
william
03-09-2002 11:03:48
what kind of liners are in my 3 cylinder dexta, dry/wet/ or is it just a bored block,i am trying to source a water leak into the sump and wonder if it has liners fitted it is not a head gasket problem as previous owner has already fitted a head and gasket.
Paddy
04-17-2002 07:08:12
 Re: dexta liners are they dry or wet in reply to william, 03-09-2002 11:03:48
Take off the head and have a look, if there is a separate sleeve, then they are wet liners. If there isn't then they are dry. The water leak coudl be the seals at the bottom of the liners.
Curt
04-02-2002 20:38:28
The Perkins 3 cylinder 152 diesel has dry sleeves. Wonder if the head was checked for warpage before reinstalled? Even a new head gasket will leak if the head is not perfectly flat....
WET
03-26-2002 14:51:22
WET
Stephan
03-10-2002 00:30:04
Hi
Dry
Regards
