Fordson Farm Power major VS Industrial Power Major
Neil
01-19-2002 05:52:11
Hi
I was wondering what is differant between a farm power major and an industrial power major.
Thanx
Neil
Neil
01-22-2002 16:59:28
 Re: Fordson Farm Power major VS Industrial Power Major in reply to Neil, 01-19-2002 05:52:11
Thanks Guys
You answered a few questions for me.
Thanks
Steven B
01-20-2002 03:38:41
The indusrial tractor has:
No PTO
No Pulley
Large drum brakes at the end of the axles ILO small drums on the bull shaft.
No 3pl
Optional trailer vacuum brakes
A large drawbar hook.
Non adjustable pressed steel rear wheels. (some export ag tractors had these wheels, eg New Zealand)
tim
01-21-2002 05:42:15
 Re: Re: Fordson Farm Power major VS Industrial Power Major in reply to Steven B, 01-20-2002 03:38:41
I have read that the industrial versions of the Majors also had a special manifold as an option that allowed the engine turn slightly faster. The faster rpms meant a little more power. The different manifold was not used in agricultural versions.
Steven B
01-22-2002 04:35:32
 Re: Re: Re: Fordson Farm Power major VS Industrial Power Major in reply to tim, 01-21-2002 05:42:15
This engine was also used in the Thames Trader Truck range. The Diesel engines had identical manifolds. The gas/ petrol engines had the same manifold but diffrent carburetors.
Engine speed on truck engines was higher than those on tractors. This was achieved by adjustment to the throtle control on the manifold on early engines and the injector pump on later engines.
I have compared the part numbers of manifolds and injector pumps of truck/tractor for engines made after March 1957 and they appear to be the same except for the carburetors.
One thing I did miss was that the industrial tractor has only one brake peddle.
Early tractor engines hade smaller injector pump bores.
Steven B (I missed)
01-22-2002 04:45:49
 Re: Re: Re: Re: Fordson Farm Power major VS Industrial Power Major in reply to Steven B, 01-22-2002 04:35:32
Diesel truck engines were set at 2700rpm no load and 2400rpm load and gas engines were set at 3000rpm. Tractor engines were set to rev much lower.
