Dexta Starters
SCJim
11-14-2001 18:36:18
A question for you old hats....I'm looking at a Super Dexta w/defunct starter. I have access to a regular Dexta starter. Will they interchange? Wanted to do this to run the tractor b/f buying!! Thanks!
Burrhead
11-14-2001 18:50:23
 Re: Dexta Starters in reply to SCJim, 11-14-2001 18:36:18
Yep it's the same starter. Good luck I hope it checks out okay I like Dextas.
If you're new to them just remember it takes a good hot battery and maybe even some jumper cables to crank it.
It should be a positive ground but you still hook the booster veh to it as usual with pos to pos, and neg to neg.
sumpin I forgot--Burhead
11-14-2001 18:52:21
 Re: Re: Dexta Starters in reply to Burrhead, 11-14-2001 18:50:23
don't use even a little bit of ether or a gas rag to crank it. Both can ruin the pistons and/or rings.
