3 cyl. perkins head
Bob
09-02-2001 19:33:38
Are there any tricks to sealing the plates below the injectors,Ihad the head reworked and had it running about two hours when they started leaking.Also where can i find a reasonable water pump?
burt
09-06-2001 14:39:43
 Re: 3 cyl. perkins head in reply to Bob, 09-02-2001 19:33:38
If you mean the cover plates on the pre combustion chambers, these were sealed originally sealed with copper washers, if you want to reuse them and they are in good condition, they may have work hardened so heat them gently to red hot then quench them in cold water. Unlike steel, this trick softens copper enabling it to make a better seal. Later seals used a tin plate gasket which have a concave cross section which is crushed when the bolts are tightened down so probably cant be used twice.
If you mean the plate which i believe keeps water in then you should be able to take this off, clean it up, and make up a new gasket out of gasket paper or you might get away with just liquid gasket sealent (the rubbery variety)
