FPM Gear oil flow from primary gear box to final transmission
Xris IOW
05-14-2001 12:07:10
My FPM suffers from oil transfer between gear boxes. So far I have renewed the two lips seals in the PTO box which was ok untill I engaged the PTO.
I next had the PTO shaft ground down by .010" to bring back the the shaft surface. Also a new twin lip seal was fitted. Same result in that every thing is OK untill I do some work (ie mowing) when the primary gear box oil level drops and the rear transmission leval rises.
Can any body help?
Mark
05-28-2001 19:19:43
 Re: FPM Gear oil flow from primary gear box to final transmission in reply to Xris IOW, 05-14-2001 12:07:10
Check the breather in the top of the gearbox. It may be blocked preventing the expanded air from escaping from within the gearbox when it warms up, thus forcing oil through the transaxle seal into the transaxle. If you have a pulley fitted, oil will probably be forced past this seal as well.
The breather replaces one of the bolts on the top of the gearbox, under the fuel tank. When removing the breather use a piece of wire to make sure the breather has not been fitted to a blind hole by mistake.
Let me know how things work out!
Regards,
Mark.
Mark
05-28-2001 19:12:33
Regards,
Mark.
john pidgeon
05-21-2001 23:42:24
hallo there only thing i can think of if the bearings are vorn or oil is no good then the seals may be getting to hot and burning out.
