Fordson County Crawlers
M Bayon
01-25-2001 07:02:49
Does any one have an info on Fordson county crawlers.
were they made, how many models etc.
Steve
04-08-2001 17:27:02
 Re: Fordson County Crawlers in reply to M Bayon, 01-25-2001 07:02:49
I have a Fordson County Crawler and after driving for about 10 minutes the left track starts to fade and it won't turn. I beleive that there is a disc clutch on the left hand side that is the problem. I started to remove the assembly, pulling about 20 little nuts off the aluminum hub then two heavy duty springs. I then removed the spring backing plate and there was a big bolt holding a plate with the dawel pins, I removed the bolt but this plate won't come off. Do I have to take off the outer internal brake band to get to the disc or....? Any suggestions would be great! Thanks.
Oscar
01-25-2001 23:16:17
Check out http://www.ytmag.com/articles/artint124.htm
for a nice story on a Fordson Crawler.
manuel
01-25-2001 15:40:49
hello M,
i don't know much about County crawlers but i can track down some info on ford County tractors if u need it.
good luck. Manuel
Lee Balchin
03-18-2004 13:33:55
 Re: Re: Fordson County Crawlers in reply to manuel, 01-25-2001 15:40:49
I have a county crawler and the tracks are clapped out , is it possible to turn it into a skid steer with 4 equil wheels?
