Dexta pivot pin lube
Jerry
01-14-2001 16:07:48
can anyone tell me if the pivot pin in front axle has a grease fitting. if it has were is it? if not how do you grease it? thanks Jerry
Burrhead
01-18-2001 15:27:06
 Re: dexta pivot pin lube in reply to Jerry, 01-14-2001 16:07:48
Jerry it does'nt have one unless somebody did a modification on it. It's easy to put one in it, but if you put a new pin and bushing in it you probly won't ever wear it out again anyway.
When you re-bush the pivot be sure to grind the caps on the torsion rods to tighten the knuckles up, and it will take all the fore & aft shift motion out of the axle and it will save the pivot pin and bushing.
Oscar
01-16-2001 09:27:14
It wouldn't hurt to add some extra oil to the gearbox and the rear differential. Don't top 'em off, though.
Filling the steering gear can be a real challenge without taking it apart. It can be done, though, see my site (FAQ).
Regards,
Oscar
Oscar
01-16-2001 09:28:55
 Re: Re: dexta pivot pin lube in reply to Oscar, 01-16-2001 09:27:14
Ooooops! Something went wrong here. Please disregard my previous message!
Oscar
01-16-2001 06:24:49
Jerry,
What exactly do you mean by the front axle pivot pin? Once I know what you mean, I'll try to answer your question.
Regards, Oscar
