Dexta Fuel Pump
Matt
10-19-2000 09:36:27
I am looking for information on the Simms fuel pump on an early Dexta. The current pump is not functioning as it should. It does not produce enough pressure. Is it possible to have the pump rebuilt? Or is there a source to buy a new or remanufactured replacment pump?
Ian Johnston
10-19-2000 10:09:29
 Re: Dexta Fuel Pump in reply to Matt, 10-19-2000 09:36:27
Matt,
Are you talking about the fuel pump or the injector pump?
I'm live in Scotland and the dealers I've phoned up so far have just laughed when I asked if they have a new Simms injector pump in stock. You can get then reconditioned or you could have a hunt round the scrappies to see if they have one that works.
Where abouts in the world are you?
Ian.
Matt
10-19-2000 12:25:16
 Re: Re: Dexta Fuel Pump in reply to Ian Johnston, 10-19-2000 10:09:29
Ian,
Thanks for responding. I am in the US in West Virginia.
Matt
Burrhead
10-19-2000 13:59:35
 Re: Re: Re: Dexta Fuel Pump in reply to Matt, 10-19-2000 12:25:16
You can rebuild either the injector pump or supply pump Matt.
The supply pump pressure should be 6 to 10 psi and the injector pump should be very close either way at 2350 psi.
Wayne A. Larson
04-23-2001 22:10:31
 Re: Re: Re: Re: Dexta Fuel Pump in reply to Burrhead, 10-19-2000 13:59:35
I am looking for Fuel pump for a 1957 Dexta.
