Dexta oil pressure switch
Jack.C to burrh
10-02-2000 19:09:34
Hello Burrhead
Can you tel me the location of the oil pressure switch on my dexta? they do not talk about that in my fo-15 manual. I check And I can't find it, maybe the old owner put a plug in place or I don't
look for the wright shape. I am looking for someting similar to the one on a diesel car or light truck. My light wire is not connect so I can't follow it.
best Regards
Jack.c
Burrhead
10-02-2000 19:37:53
 Re: dexta oil pressure switch in reply to Jack.C to burrhead, 10-02-2000 19:09:34
Just to the rear the fuel injector pump, and just a little lower. It's only about the size of one joint of your middle finger and sticks straight outwards toward you below the fuel filter.
Jack.c
10-03-2000 16:51:20
 Re: Re: dexta oil pressure switch in reply to Burrhead, 10-02-2000 19:37:53
Hello Burrhead
guest the plug that the old owner place instead won't indicate much hey? do you happend to know any replacement part form NAPA or carquest that would do the trick ?? or mecanic indicator that would have the wright size of tread.
thanks again for the indication burrhead
best of the best regards
Jack.C
Burrhead
10-03-2000 18:53:44
 Re: Re: Re: dexta oil pressure switch in reply to Jack.c, 10-03-2000 16:51:20
Hello Jack I get the 2" gauges and replace the light with a mechanical gauge. Ford or Perkins can get you a new sending unit, but I don't trust them anyways.
The electrical unit is made to light up when the oil pressure drops to 7 to 9 psi.
The crankshaft bearings will start to score and gald up before the light comes on.
It is possible to burn the crankshaft out of this engine before the warning light comes on.
Look on the bright side Jack one day you'll have a new Dexta.
Bon chance et abiento. Jerry
Jack.C
10-04-2000 05:23:25
 Re: Re: Re: Re: dexta oil pressure switch in reply to Burrhead, 10-03-2000 18:53:44
I guest I will follow your advise, I will install a mecanical gage.Do you know the normal operating oil pressure for this tractor? and also what is to low or to high
Thanks again Jack.C
Burrhead
10-04-2000 09:32:17
 Re: Re: Re: Re: Re: dexta oil pressure switch in reply to Jack.C, 10-04-2000 05:23:25
Yessir the normal operating pressure should be around 40 psi with engine warm at 2000 rpm's.
It should run about 20 psi with the engine warm and at idle speed.
The oil pump relief valve opens at 60 psi so it should'nt ever run over 55-60 psi.
Jack.C
10-04-2000 10:15:07
 Re: Re: Re: Re: Re: Re: dexta oil pressure switch in reply to Burrhead, 10-04-2000 09:32:17
thanks again for this info burrhead
Regards
Jack.C
