Fordson Tractors Discussion Forum |
Fordson F and 560 Dennis
Author |
[Modern View] |
james williams
02-23-2021 16:30:07
please help my stupid self.I am working on my coil box,and I got several friends with model Ts they can show me but cant explain nothing.I under stand the 4 wires going to the plugs,and I understand the 4 wires from the rotator.Im concerned about the bottom strip in the coil box and what wire goes to it.Is this tractor negative ground Im going to run it off of a battery,where does the positive and negative wire from the battery hook up to the tractor?I have studied ever photo on utube but I cant tell where the battery leads go
james williams
02-24-2021 09:15:17
Re: Fordson F and 560 Dennis in reply to james williams, 02-23-2021 16:30:07
I talked to Skip at the Fordson house and I think he answered my question.When running on a battery the positive lead on the battery goes to the bottom strip in the coil box,and the negative battery post grounds to a bolt on the tractor
560Dennis
02-24-2021 06:50:01
I used the 6 volt battery (charged up) out of the Farmall C with jumping cables . I removed the cable from flywheel contact , I put the jumper positive to that coil cable . And the other negative cable to the stud for coil box or good ground . Here are some dont say Dont have the 🧲 magneto cable hooked flywheel ever if using the battery ,it will discharge the magnets 🧲.on flywheel Dont let the coils buzz for any length of time ,it will heat up tar in coil and boil out of coil ❗️Rotate crank so that coil stops buzzing We (with battery start , retard spark ,its a must do . Rotating hand crank to the one oclock 🕐 position and use are leg pushing down to start .ours starts cold one kick . If your using mag to start you need to whirl the hand crank to start to build up current. About two turns as fast as you can , keep your face away if it kicks back ,that why you retard spark ,dont put thumb around handle .. I see a lot guys on you tube do it and they are asking for a broken arm or a expensive dental repair. Thats about it , all Fordson s are different so depending on the conditions of your tractor ,this is only a start I can recommend.
james williams
02-24-2021 14:21:19
Re: Fordson F and 560 Dennis in reply to 560Dennis, 02-24-2021 06:50:01
Thanks for the info.Im a looooong ways from starting,Im just studying right now
warbaby
02-24-2021 06:12:09
Your bottom coil terminals are for the constant voltage supplied by the flywheel magneto ( from that terminal on the L.H. bellhousing, facing towards the coilbox and just above the parting line between the block and oilpan castings). As long as the engine is turning, there is (ideally) enough juice being supplied here to make your coils buzz. The purpose of the Rotator/timer is to supply a ground to the coil which completes the electrical circuit and allows the coils to energize in the correct sequence (the firing order). It seems confusing at first, but those wires from the timer are not "hot", they are just isolated grounding wires. If you are going to bypass the flywheel magneto with a battery, you can hook the bottom strip to one terminal of the battery and ground the other to the tractor so the timer will pick it up- it doesnt matter which terminal you use. IF you are going to use BOTH the Flywheel magneto AND a "helper" battery to start the tractor, you MUST isolate both ignition systems! A SPDT switch must be used so that only one system is connected and active at a time to prevent electrical damage between the two.
560Dennis
02-24-2021 06:24:00
Re: Fordson F and 560 Dennis in reply to warbaby, 02-24-2021 06:12:09
Very clear photo ,nice post better than I have seen ,thank you
warbaby
02-24-2021 06:32:39
Re: Fordson F and 560 Dennis in reply to 560Dennis, 02-24-2021 06:24:00
Sorry, I didnt mean to step on your toes here by jumping in early- I hope you took no offense. Us Fordson "F" (and N through E27N) guys gotta stick together!
560Dennis
02-24-2021 06:54:16
Re: Fordson F and 560 Dennis in reply to warbaby, 02-24-2021 06:32:39
Not me , press ahead , I didnt , Ima rookie with Fordson F so ! I like the photo , best Ive seen, one I got cant make out details like in your photo thank you
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance."
... [Read Article]
Latest Ad:
Single front for Int M, 706
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
