Fordson Tractors Discussion Forum
Advice on push rods.
Richard Hare
04-30-2008 21:36:58
I do not mean to be hogging things here, but have a Q. re. my bent push-rods.
Tractor is th FSM in nearby threads.
Was started using decompression lever for years.
5 of the push-rods are bent.
Q; Should I straighten them, or find replacements?
If straightened, will they bend again with use?
Thank you in advance!
Rich.
Mike Farmer
05-02-2008 12:17:07
 Re: Advice on push rods. in reply to Richard Hare, 04-30-2008 21:36:58
Hi I suggest you just straighten them I've done it quite successfully on numerous occasions but dont use heat MTF
Richard Hare
05-02-2008 21:01:58
 Re: Advice on push rods. in reply to Mike Farmer, 05-02-2008 12:17:07
Thanks for the answer Mike.
When the rods get bent like this from using the decompression to spin over engine to start, does it generally hurt the valves or pistons?
I ask because one of the push-rods has the ball at lower end a bit flattened.
Not sure if I should pull the head off, take a look and do valves, or just try it & see how she runs.
W R
05-01-2008 04:35:31
I have straightened them and didn't have any
problems.
Richard Hare
05-01-2008 07:28:56
 Re: Advice on push rods. in reply to W R, 05-01-2008 04:35:31
Thank you for the input, If I can't find any straight ones, I'll attack these!
Cheers,
R.
