Fordson Tractors Discussion Forum
1959 dexta diesel smoke
ray jewel
04-07-2008 11:54:59
rebuilt motor but still smokes,not oil fuel also rough idle.Could this be bad fuel pickup pump,or problem in injecto pump?Thanks,Ray
cowman1
04-07-2008 20:27:15
 Re: 1959 dexta diesel smoke in reply to ray jewel, 04-07-2008 11:54:59
These engines need to be broke in. A bad Diaphram will not make it smoke the engine will go to full throtle with no responce. That is if it it is the Pnenmatic model. Which it should be.
mmmpuller
04-08-2008 16:05:36
 Re: 1959 dexta diesel smoke in reply to cowman1, 04-07-2008 20:27:15
The engine won't go to full throttle because it can not get enough air through the venturi. A small leak in the diaphragm will cause smoke at idle but will clear up some on full throttle and go back to smoking the more idle time it has.
tiresntracks
04-08-2008 21:50:41
 Re: 1959 dexta diesel smoke in reply to mmmpuller, 04-08-2008 16:05:36
I agree. I think its a bad governor diaphram, too. Click on "Tractor Parts" in the top left corner of this page. You can get a new diaphram for a real good price there.
mmmpuller
04-07-2008 14:56:44
If your dexta diesel is the one with a vaccum govenor on it, it could be a bad diahpram in the pump that would let the pump have too much fuel when it is a idle for the amount of air it can get. It is a common problem with these and it can be replaced while the pump is still on the tractor. I hope this info is of some help to you.
