Fordson Tractors Discussion Forum
Fordson F Warning
Richard in NC
04-02-2008 08:59:14
This might be important to know! I just had my 23 Fordson F sleeved back to a standard bore. The machine shop left a 5/16 inch lip at the bottom of the block to keep the sleeve from ever being pulled into the crank. When I installed the first piston assembly to the crank and started to rotate the crank the oil ring on the bottom of the piston hooked the bottom of the sleeve locking everything up. I had to beat the sleeve out to get the piston out. The machine shop is going to use a different style sleeve that has a lip that locks in at the top of the block. Hope this helps someone!
