Fordson Tractors Discussion Forum
Crankshaft Rear Oil Seal
Steve Rosa
10-31-2007 06:40:32
I need to replace the crankshaft rear and front seals on my Super Dexta. (Oil leaks on both seals)
According to the manual you have to separate the engine and front axle assembly from the gearbox to replace the rear seal.
Some people have told me that the rear seal can be replaced by just dropping the oil pan. I would appreciate any advise on the subject.
Bendee
11-08-2007 18:15:40
 Re: Crankshaft Rear Oil Seal in reply to Steve Rosa, 10-31-2007 06:40:32
Best to follow the manual then you won"t have to do it a second time.
fordson64t
11-01-2007 18:00:00
I replaced the rear main seal on my 64 fordson super dexta. The seal is behind the flywheel. It is a 2 piece rope seal that straddles the crank. Removing the pan will not get you to it on mine. Mine has started leaking again.
