Fordson Tractors Discussion Forum
Major Hi Low trans problem
JD dozer mike
12-28-2006 13:12:45
the hi side works fine but low range wont go in.
Common problem? Linkage maybe? Bent forks?
I know this is a very broad question , but i have not seen the tractor yet , but will be looking. single stage clutch model.
R Wooley
12-29-2006 19:10:14
 Re: Major Hi Low trans problem in reply to JD dozer mike, 12-28-2006 13:12:45
I had Same problem with mine - remove cover for belt pulley the nut that holds bevel drive gear for the belt puley in place has probably come off. this will prevent shifter motion. I have heard it is a common problem ford redesigned a split nut to fix problem.I had to remove trans. to fix mine, threads were mest up from trying to engage gear. the 2 stage clutch uses a different hi / low shifting mechinism. no nut for bevel gear.
