Fordson Tractors Discussion Forum
1938 Fordson serial number 2243 or z243 or zz43
Robert Gayer
07-03-2006 15:00:45
I have found the serial number on my 1938 Fordson thanks to the forum, although the numbers are not very plain. The top two numbers appear to be 2's but are written differently than the two digits underneath which are clearly 43. Looking at the edge of the flange, the two top digits are written so you can read them as 2, and undernath the 4 and the 3 are turned sideways. ASny way to clarify?
Robert Gayer
07-04-2006 18:33:49
 Re: 1938 Fordson serial number 2243 or z243 or zz4 in reply to Robert Gayer, 07-03-2006 15:00:45
Thanks for your quick reply. I will check for the correct serial number and post it.
Scott PA
07-04-2006 17:43:19
If you got this number on the trans. to engine flange, it is the 4.3 gear ratio, the serial number is stamped above the manifold between the 1st and 2nd ports on the engine block and would be 6 digits long.
