Fordson Tractors Discussion Forum
Majorman
vidar
05-16-2006 10:03:04
Dear Mr Majorman. I have change two orings on the pipe from the pump, and the hydraulic was ten times better.
there is also a similar pipe from the valve chest.
is it a part of the feed pipe?
This is a Fordson diesel Major ASP 1955
The problem was: I need full power to lift the hydraulic.
Best regard Vidar Holmen
Majorman
05-16-2006 10:58:54
 Re: Majorman in reply to vidar, 05-16-2006 10:03:04
The "O" rings may need changing on all the pipes but the most likely cause of your problem is in the hydraulic pump. Both pipes are the main pressure feed to the lift.
