58 Power Major Diesel
Cold Weather Start
John DeRung
01-22-2000 19:23:47
Looking for cold weather starting instructions
for the 1958 Power Major Diesel. Specifically,
how to use the decompresion arm to aid cold weather starting.
Thanks!
John
Don(CO)
01-23-2000 09:26:14
 Re: 58 Power Major Diesel - Cold Weather Start in reply to John DeRung, 01-22-2000 19:23:47
John:
First, if you do not have a block heater or lower radiator hose heater; I would suggest consideration of that to ease cold weather starting of the Fordson diesel. The decompression lever fitted at the front of the valve cover/head assembly should be in the 'UP' position for decompression. This is intended for lowering the compression of the cylinders when using the handcrank. Over the years and generations later, this has practically become an obsolete option to most operators. The starter motor may be used to turn the engine over in the decompression mode....SPARINGLY. The original intent of the decompression lever was to turn the engine over with the crank to lubricate the system and ease the strain on the starter motor. Your Simms injection pump should have a small "excess fuel button" commonly referred to among Fordson enthusiasts as the "easy start button" Push this button "IN" when cold starting. The button is located at the rear of the injection pump near the fuel shut off lever cable mechanism.
In summary, if you have a block or lower radiator hose heater, you'll have no need to use the decompression lever. Push in the excess fuel button, be sure the tractor is out of gear and the clutch pushed in to reduce engine drag, engage the starter motor lever with the key on and your Power Major should spring to life.
As a footnote, I have known some Major owners who have had their tractor for years, and were not aware of the excess fuel button for cold starting.
Keep us posted how things go!
John DeRung
01-24-2000 20:41:32
 Re: Re: 58 Power Major Diesel - Cold Weather Start in reply to Don(CO), 01-23-2000 09:26:14
Ok, after putting a block heater in and letting
it warm up it turns over and I get a little exhaust before my battery gives up the ghost. The
battery doesn't last more than 5 or 10 seconds so
it looks like I need to go battery shopping. The battery that's on the tractor right now can't be
the right one since I can read the word "marine" in two places but thats about it for legable text.
Anyone have any suggestions for a replacement battery for a 1958 Power Major Diesel?
Thanks!
John
John DeRung
01-30-2000 12:17:15
 Re: Re: Re: 58 Power Major Diesel - Cold Weather Start in reply to John DeRung, 01-24-2000 20:41:32
Ok, I've installed new battery. It turns over
"MUCH" better. Still might replace the positive
cable since its worn really bad. But, all I get
when it turns over is alot of whitish smoke. I
tried placing the throtle in a few different positions but that did not help either. I did
push the excessive fuel button also.
While searching through the tractor I found a can
of ether in the tool box.... hmmm, I suspect the previous owner used it to start the tractor.
Should I just give up on trying to use it in the winter until I can overhaul it? Or is there something else I should look at? Drain fuel and
replace?
Thanks,
John
BLB
01-26-2000 08:32:40
I have a 1959 Power Major, and have had cold weather starting problems for some time. Last year I replaced the batteries. I put in two six volt 600-800 (can't remember exactly the CCA) cold cranking amp batteries in series. Simply bought A-1 Auto batteries on sale.That's the original manufacturer's battery set up as I understand. I also thoroughly cleaned all electrical contacts. That solved most of my cold weather starting problems. The old girl will snap to life down to about 15-20 degrees F with only conditioned fuel to prevent gelling, and a push of the extra fuel button on the injection pump. Below 10-15 degrees a little block heat is usually needed. I wish I had been smart enough to have done that years ago.
Oscar
01-25-2000 06:19:33
There are lots of good battery manufacturers out there. Over here in Europe, I'd recommend Varta or Vetus. Doesn't really matter, as long as its capacity is as high as you can get it, preferably over 100 AH (ampere-hour). This number reflects the total amount of electric charge the battery contains when fully loaded. The higher it is, the longer it takes before the thing goes dead on you, and the higher the current it delivers is. This current is expressed in Amperes, and tells you how much electric charge the battery can give you per second. Inside your house, for domestic use, the current won't go far above 10 Ampere before the fuses melt. A good tractor battery can deliver enough current to make regular electrical wire glow up in the dark!
Burrhead--Hey Oscar
01-31-2000 19:30:47
 Re: Re: Re: Re: 58 Power Major Diesel - Cold Weather Start in reply to Oscar, 01-25-2000 06:19:33
I've noticed there are alot more Dexta and Major parts available on your side there. Do you know if there is any hardship in purchasing from there and shipping to America.
