Order Ford 800 Parts Online
1957 800 series oil pump
Todd Rand
07-04-1999 16:57:40
I pulled the distributer to overhaul and I think something dropped off and fell down to the pan. After reinstalling the distributer and starting up the valves clattered much louder than usual and shortly smoke started venting out of the filler cap and valve cover vent. I am assuming that the oil pump and distributer run off of the same gear assembly and I now have a missing link and no oil pressure. Until I can find an assembly diagram any help?
Moye
07-05-1999 18:53:32
 Re: 1957 800 series oil pump in reply to Todd Rand, 07-04-1999 16:57:40
You sure did drop something, the oil pumb dirve shaft. It fits into the oil pump and the distributor and is driven by the dist. You will probably have to pull the pan and the pump to replace it. Hope you didn't do any severe damage to the engine, but I would pull a rod cap and a main bearing cap while I had the pan off to be sure. Good Luck
Moye
07-05-1999 18:52:56
Todd
07-08-1999 07:25:05
 Re: Re: 1957 800 series oil pump in reply to Moye, 07-05-1999 18:52:56
Thanks Moye, I was thinking of dropping the pan for exploration I know what to look for now. I'll take a look at those bearings while I'll down there too.
Todd
