Order Ford 640 Parts Online
Ford 640 vapor lock
paul ward
06-24-1999 19:43:16
Help!!! this thing is driving me nuts. Just started vapor locking last summer. Now I can't get it to stop. Someone let me know some suggestions on rerouting the fuel line, or even insulating it.
Jogg
06-27-1999 14:29:54
 Re: Ford 640 vapor lock in reply to paul ward, 06-24-1999 19:43:16
Paul, I had the same problem with my 861. Aluminum foil backed fiberglass insulation under the gas tank and wrapped around the fuel line stopped it cold (so to speak). Good luck!
Harry
06-25-1999 19:29:43
try to check line while running; make sure no hot fumes are blowing on any part of it. Friend of mine had leaky exhaust manifold gasket heating the line up, once. You can try wrapping line w/ aluminum foil, shiny side out... Good Luck.....
Harry
06-25-1999 19:28:50
try to check line while running; make sure no hot fumes are blowing on any part of it. Friend of mine had leaky exhaust manifold gasket heating the line up, once. You can try wrapping line w/ aluminun foil, shiny side out... Good Luck.....
