Re: '78 not made???
Joe M
06-12-1999 21:22:41
open the hood and look on the serial number tag for the UNIT number it will have a number like " 5A15C " First number is the year ie 65,75,85,95
Letter is the month A=Jan B=Feb etc note they skip the letter I because it looked too much like a one
second set of number is the day of the month
last letter is the work shift A= day B= evening
C= night shift
if the tag under the hood is gone, this same number is on the trans housing along with the serial number
good luck !
Eric Krauska
06-12-1999 21:59:42
 Re: Re: '78 not made??? in reply to Joe M, 06-12-1999 21:22:41
Okay, thank you for the help, but if it is a "5", how am I to know if it was built in 65 or 75? Any way of telling the full year?
Thanks for the quick response, I can tell this board is going to be a great help to me.
Thanks again,
Eric Krauska
joe m
06-14-1999 19:16:10
 Re: Re: Re: '78 not made??? in reply to Eric Krauska, 06-12-1999 21:59:42
1965,66,67,68 and a few 69 had louvers in the hood
also the grille bottom section on the 65 66
curled around the sides a little the later ones were flat
1965 serial number starts C100000
1975 starts C448101
Joe M
06-12-1999 21:26:26
By the way.....the best I remember, there isn't a bracket for the light duty ftont ends, only for the 4000 series w/ the straight axle.
Put weights on this front end with care, the axles were well known to break at the axle pivot area, this often took out the radiator and both radius arms when they broke.
