Order Ford 4000 Parts Online
Ford 4000 Select o Speed
Terry Bartlett
06-06-1999 12:44:37
My Ford 4000 (Gas) stops running after a short time. Once it stops running, I get 6 volts to the distubutor when I turn the key to off. When I turn the key on, it drops to about 1.5 volts. After I wait for some time, it returns to a reading of 6 volts at the distributor when the key is on the on position. It will then start and run fine. It started doing this after I hooked up the lights that were disconnected under the dash. I got it to run longer after I disconnected them again. It will run longer, about 30 minutes before it shuts down.
